I have a 12vdc supply and need to send V- through a normally closed alarm contact (reed switch) so that when the switch is closed (circuit is made) an LED will be turned off. When the switch is open (circuit is broken), the LED will be turned On. I need to do this with multiple reed switches and multiple LEDs, each operating independently. I thought I could accomplish this with a Hex Schmitt Trigger MM74C14N (6 in / 6 out) but it doesn't seem to work the way I need it. I have tried both 12v and 5v on the supply and the inputs. In both cases it does turn the LED off and on as desired, but it affects all the inputs and outputs. So for instance when I remove trigger voltage from one input, all the other inputs and outputs have voltage and all 6 LED's are on. They are operating collectively, not independently. In testing, I hooked up an LED to output 1, nothing on the other inputs/outputs, but when trigger voltage was removed from input 1 , all the other inputs and outputs also have voltage at their pins. Its the same case of collective, not independent operation. I don't know enough about this IC to know where I have gone wrong or what I should do to correct this if this IC will work the way I need this circuit to operate. Any help is appreciated.
Platforms
Content
