Hi All,
I'm new here and hoping I can work with some of you to understand this circuit. I studied electronics a long time ago (the '70s), and have built a few things over the years. I have a ham radio license (WA4LDA), and know some things about electronics. Alas, I don't know as much as I thought I did, at least not where this circuit is concerned.
The schematic is for a full-duplex intercom ("full-duplex" meaning that everyone can talk, and be heard, at the same time, like a telephone party line). Some things about it make perfect sense to me, but others are baffling. I've included a .png of the schematic in this post, but a detailed .pdf is available online.
My first question is about how the signal from IC1 is mixed with the signal arriving from the intercom audio bus through C6. It looks to me like IC1 is part of an inverting amplifier that amplifies the signal from the microphone. Now, I think that the voltage at Pin 1 of IC1 is always positive, the sum of the potential from the "half supply rail" and the amplified audio signal. Assuming the supply rail's potential over ground is 12 volts, that would put the half rail at 6 volts, and the output from IC1 would center on 6 volts, with a peak-to-peak variation of, let's say, 3 to 9 volts (no idea if that's what it actually will be, but it has to vary from some amount 6-dV to 6+dV, right?). Now, I am thinking that C5 passes the audio from that signal, but filters out the DC. Thus, a -3 to +3 signal is applied to R9 (and to the much larger impedance of R8). This AC signal is simply added to the AC signal passing from the intercom bus through C6.
And that's where I go crazy, because I can't make sense of how the intercom signal both gets mixed with the output from IC1, so that it can be fed to IC2 (and heard in this unit's headphones), and gets mixed with the intercom bus, so that it can be fed to to everyone else (and heard in every other unit's headphones). Is it becaues the voltages all just add together, and IC2 is a high-impedance-input voltage amplifier? If so, why is C6 needed?
Also (and here is where I really get confused), what happens if the sum of the AC voltage from C5 and the signal from C6 add together to exceed the voltage from Pin 1 at IC1? That is, suppose Pin 1 is at 3 volts. The AC from C5 would be at -3 volts, so the drop across C5 would be a full 6 volts. What guarantee is there that the sum of the voltages from all the other units wouldn't deliver more than 6 volts through C6? If that were to happen, wouldn't that mean C5 would be "reverse biased?" (Does that phrase even apply to capacitors?) Or, are the AC signal voltages on the intercom bus so small that, absent an improbably large number of them, there is no risk of them adding up to more than the "half supply rail" voltage?
Thanks for any help. Looking forward to learning more on this forum.
