This is a plate amp from a JBL PS1400 400W subwoofer amplifier. I have tried a few things, as outlined below, but my limited knowledge has been exhausted. Any help is appreciated.
Amp version: Rev - 03D 11/06/2000
All references to components are based on the PS1400 service manual and circuit board.
The service manual (and schematics) can be found here:
http://www.jbl.com/resources/Brands...cuments/en-US/ServiceManual/Ps1400 Sub SM.pdf
1. The first sign of trouble was when I noticed there was no output, the leds were red, and sometimes the leds would turn green for a second and would power the speaker. I checked the driver and installed the working amp from the other PS1400 in where the faulty one was and it worked fine, so I am pretty sure the problem is just within the amp itself.
Action taken:
a. I bench powered the amp and found nothing that would indicate that the amp shouldn't be working. Because transistors are often the culprit, I removed the output transistors. I then bench powered the amp and the relay sounded like it was functioning so I thought I had it figured out.
b. I ordered new transistors and changed the output transistors Q11, Q13, Q15, Q17
c. I then bench powered the amp and it appeared to be working
d. I also noticed visible dark spots on PCB board where R76 and R78 mount. It was the same on the board of my functioning PS1400. See pictures below of functioning board:
2. After reinstalling the plate amp it ran for a few minutes then back to red LEDs. I could hear the relay clicking.
Action taken:
a. I saw that the fuse had blown. I replaced the fuse from the working amp.
3. I powered the amplifier on the bench. PCB board shorted., D3 was melted, Q8 was visibly broken
a. Replaced D3, D?, R76, R78, Q5, Q8
b. Soldered over fried area of PCB board
3. Amplifier LEDs powered straight to green, but no output, burning smell
a. The PCB was fried again in same place; fixed, replaced burnt out U4
b. removed and tested bridge rectifier, diodes tested good.
c. Measured transformer resistance through DMM, both good and questionable had same measurements both VAC powered and Ohms while off.
4. Hooked up board to known working amplifier’s transformer. Blown fuse, no other visible damage.
5. I put in the new capacitors and this time Q17 blew up and then before I could even flip the switch, the fuse blew. See picture below with the offending transistor circled and you can see the new caps as well.
I took all of the power transistors out and fired it back up (with yet another fuse -- I'm getting low!). No pops or blown fuses. I was able to get my DMM in there to measure some voltages.
V+ 50V
V- -49.9V
+15v cycling between ~13v and ~16v
-15v -10v
No clue what the problem is. Maybe to voltages are off because I have the power transistors out and they aren't drawing power, but I suspect that some component is either open or shorted and/or a voltage regulator is bad. I guess I will take a break for a bit and then come back and do a ton of voltage measurements and try to figure out what the problem is.
Other things I may try:
1. Replace the output transistors again
2. There were a couple differences between my board and service manual schematic. Ex: R 76 and R 78 were not 820 Ohms, they were very close though. I wonder if there are any other changes?
Pic of the top of the board:
Note: you can see the replaced resistors R76 and R78. They are both 820 Ohms and 4 watts.
Any other ideas?
Action taken:
Action taken:
V+ 50V
V- -49.9V
-15v -10v
Any other ideas?
