Let me start saying I am a barely started beginner with electronics.
I have a Star Trac Edge elliptical 4630 with dead electronics.
I just bought the trainer 2 days ago and started trouble shooting. Previous owner said the trainer did work but would display a "service needed" message. Recently the display and all electronic control stopped working.
I have partially dismantled the trainer and it seems mechanically intact.
Problems I have found so far..
-Dead battery. 6v battery charged by an alternator on the trainer showing 0.65v.
-Alternator, quick initial testing showing no output
-Resistor with a melted connector
Attempts at fixes so far:
-Connect 6v SLA battery to battery leads of the trainer. Battery was around 4.8v at time of initial testing and I was reading around 2.5v on the load control board (main circuit board on the machine). Tested at points on the board labelled +6v and ground. This was done before discovering the burnt resistor connector.
What I need help with:
-Resistor is no longer available from Star Trac, unlikely would have bought from them anyways since prices are obscene. The resistor is labelled with "YESO 0103" and "QR300w0.5[ohm]K" (sorry don't know how to make an ohm symbol).
My inexperience shows here though. I am trying to test the resistor. Using my multimeter I first set it to 2K and tested getting a reading of 0.002ohm. Tried again at the 200 ohm setting and getting 1.0 ohm. On Monday I plan on going to Tobrams Electric supply (TES) and talking to them about resistors and possible replacements for this resistor.
Will try testing the alternator again. IF the alternator is truly blown like I am thinking that would explain why I can't get the display to turn on with a surrogate battery since the trainer does not know it is being used.
Big hope here is that the blown resistor did not kill the board.
Any help or suggestions would be great, even confirmation that I tested the resistor right would be great. Also if you would like any pictures of anything ask and I get them up here.
Thanks in advance for any help you guys can offer.
