John O'Flaherty
phaeton said:That's what I had thought. Jameco lists them as a 'power mosfet', but
I immediately noticed the case style. I looked at the datasheet they
supplied (which turns out to be from the wrong manufacturer anyways),
and since it was rated for "0.83W max" I figured maybe it didn't need a
thermal plate built in. (like the LM386 chipamp- no heatsink there for
500mW)....
So actually, this device is more in the 'small signal' neighbourhood
like the J201, BS170, etc, instead of anything you'd associate the word
"power" to?
That silly Jameco. Always pullin pranks... Anyways...
With a 22 ohm drain resistor and 8 ohms dc resistance in the speaker,
the max power in the FET would be at 4.5V drop and 4.5V/(30 ohm)
current, or 150mA. That would give you a max dissipation of 0.675W. The
transistor might have needed a heat sink, but it should have been
alright. To get maximum symmetrical swing out of this circuit, look at
the extremes of full off and full on. When the FET is full on, the
speaker voltage is 8/(22+8)*9V, or 2.4V. That means the speaker output
should be biased for 1.2V This would be at 150mA where the transistor
dissipation is .675W. Then, any audio you put into it only decreases
the dissipation.
{snipped}
Turning the pot has no effect on the reading I get at the Gate.
Furthermore, Forrest noted the pot as being a gain control, not a bias
control (the opposite of what I would have guessed by looking at it).
It does affect the bias, though. With a different transistor, you might
need to change R1 or R3 to accommodate a different cutoff voltage for
the FET. If you can adjust those resistors for 1.2V output at the
speaker, it will just _have_ to amplify.
