Thomas Anderson
Hi!
I want to charge a capacitor to 300 V from something like 5-15 V.
Because I can't find 400 V MOSFETs for 10-50 mA which would have a
suitably small gate charge I tought a BJT would be the solution for
simple and fast turn off:
MPSA44
NPN Transistor
400V
300 mA
http://www.datasheetcatalog.com/datasheets_pdf/M/P/S/A/MPSA44.shtml
The specs talk about frequencies up to 20 MHz (VCE=10V).
Philips even says 100 MHz:
fT transition frequency
(IC = 10 mA; VCE = 10 V; f = 100 MHz)
20 MHz (max)
Since there is a turn on and a turn off in one period the turn off
time should be something like 1/40e6 = 25 ns or less since there may
be some duty cycle between switches. Well, things may be different
at VCE=300V and Motorola only mentions 10 MHz.
And now I am confused by the turn on/off timing diagrams in the
Motorola specs (page 4) (VCC=150V; IC/IB=10 (saturated?)):
There is ts (storage? time = BE junction discharge time?) and tf
(fall time = IC fall time?) given for IC = 1-50 mA. Do I have to add
these times? Why is the turn off time higher for smaller IC? Ohh, is
it because turn off is when IC drops below some % of initial IC and
not below some fixed value? So when I have IC = 30 mA, is my turn
off time then 3.3 us (ts) + 0.5 us (tf) = 3800 ns? That's a lot more
than 25 ns.
I wanted to use a 1 mH inductor which would loose 10 mA in 33 ns
when charging a cap at 300V:
I=U*t/L
t=I*L/U
t = 30 mA * 1 mH / 300 V = 100 ns
So I need a bigger inductor anyways (also because I have a 75 ns
diode), but if this transistor really has 3800 ns turn off time I
need a different approach. Any recommendations for a transistor? I'd
prefer the inductor current to remain below 50 mA.
Thanks!
This message was sent via two or more anonymous remailing services.
MPSA44
NPN Transistor
400V
300 mA
20 MHz (max)
than 25 ns.
I=U*t/L
t=I*L/U
Thanks!
