In answer to a previous question which basically asked why an arrangement like this was not suitable:
If the load on the top transformer increases, the current through the primary winding wants to increase. In order to do this, the current through the bottom transformer must increase also. This will result in a reduction in voltage across the top transformer's primary and an increase in voltage across the bottom transformer's primary.
The result is that the top transformer's secondary voltage falls, and the bottom transformer's secondary voltage rises.
Edit: the problem does not arise if the transformers share their core (i.e. they are a single transformer)
