Hello guys!
I've been doing experiments with a relatively strong step-up transformer which I've been using to test how frequency on the primary coil affects output voltage. I've done research online and many times I've read that frequency will have very little effect on output voltage but my findings contradict this.
Here's what I found from doing tests (all at low frequency and low voltage):
At 20Hz and 1.5 volt on the primary I got on average 90.2 V on the secondary.
At 16Hz and 1.5 volt on the primary I got on average 62.2 V on the secondary.
At 12Hz and 1.5 volt on the primary I got on average 50.1 V on the secondary.
Does this make sense to anyone? Or is there something seriously wrong with my experiment?
Thanks!
Thanks!
