JoeP
I bought a small portable generator and had an electrician install a
manual transfer switch on my house.
A 30 amp 120V/240V twist lock cable goes from the genset to a receptacle
on the side of my house. Inside I can cut six circuits over to the
generator and isolate them from the line.
The electrician did not install a grounding rod for the generator
outside. Is the ground through the transfer switch to my house ground?
I was going to buy a grounding rod and pound it in the earth outside and
hook the generator's frame to that when in use. But I am concerned that
this will make a duel ground system when it is connected to the transfer
switch.
switch.
