Where the schematic tells you to.Where should I connect the speaker?
Platforms
Content
I think the question is how to find which "common" or center pin on that multi-pole switch
So what's their common pin?
Here is the connection of the switch, where should I connect the speaker? Or does any of that four is ok?there ISNT a single common there are 4 commons for the 4 switches
those 4 switches just happen to be tied together in a single package to that when 1 is operated, all of them operate at the same time
No! What AG drew are not jumper wires or copper traces. They're movable bars internal to the switch. He's indicating which contacts are closed (shorted) in the switch positions indicated.When I translate it in the actual pcb layout, does the copper for the pin ( the pin before the common pins ) is connected to the copper of the common pins?
So you mean that in the pcb, all 12 pins have individual copper and non are connected to each other ? (just like what I send in the picture)No! What AG drew are not jumper wires or copper traces. They're movable bars internal to the switch. He's indicating which contacts are closed (shorted) in the switch positions indicated.
Chris
Yes, that's correct. This [ and this ] are inside the switch.So you mean that in the pcb, all 12 pins have individual copper and non are connected to each other ? (just like what I send in the picture)
I tried to find an animated slide switch on the net but didn't get any hits. The visual would help you understand.
Chris
The volume? What the slider is for?The arrow above the 39nF capacitor is the slider of a 10k ohms potentiometer. It is used only when the switch is in the Transmit mode. What do you think it adjusts?
Thus I need a slider potentiometer or just a potetiometer ?The volume? What the slider is for?
The arrows "indicate" the 4 common pins.And those 4 arrows will be connected to their 4 common pins, is that right?
