Toshiba SDV398 Stops recording prematurely
Boris Mohar
Toshiba SDV398 VHS/DVD combo with built in tuner.
Everything works but occasionally it stops recording about 15 minutes short
of programmed time. The clock keeps the correct time and the tape is new.
N_Cook
with a stop watch , check it is exactly 15 minutes to the second or just
plus or minus 5 minutes say, for 1 , 2 and 3 hour records , also try with 3
hour and 4 hour tapes to see if there is a difference
N_Cook
Arfa Daily said:
What happens if you play a tape back for the same length of time ? Could be
a simple mechanical problem like a poor take-up drive that struggles to keep
the take-up reel turning when a certain weight of tape has been wound on. If
the take-up reel stops turning, the mechanism control micro will stop the
machine.
Arfa
the most likely reason.
Either loss of friction in a slip clutch or wear in a pivot allowing a
pulley in the jockey wheel assembly to touch the chassis, both situations
when sufficient diameter of tape has built onto the take-up spool to trigger
the loss of drive
Boris Mohar
machine.
Arfa
It never fails on playback. Could there be some subtle transport load
difference between record and playback?
Regards,
Boris Mohar
Got Knock? - see:
Viatrack Printed Circuit Designs (among other things) http://www.viatrack.ca
void _-void-_ in the obvious place
W
William Sommerwerck
15 minutes short of programmed time. The clock keeps the
My first VCR, circa 1981, had a timer problem connected with an incorrectly
designed chip. If you set it to (say) start recording at 11:30PM and stop at
1:00AM, it would often quit at midnight.
N_Cook
So a divide by zero / year 2000 type problem with that one. I would have set
the clock 12 hours out on that one, assuming only recording over midnight
and never noon
Perhaps the OP should take a careful note of times , assuming there is a
timecode recorded , then see if there is a consistency in the drop out times
at recording.
N_Cook
I just looked through my repair tips , maybe relevant
Ferguson FV21
Manual record and short lead-time timed record OK but failure
of overnight record.
Replaced the the 3 small electrolytics on the clock / timer panel
and broke / inspected /remade all connections and
also at someone's suggestion tightened all earthing point through-pcb
screws on the various boards.Somewhere along the line must have
effected a cure.
