N_Cook
Probably a generic DVD mechanics question.
One motor for sledge , optical deck up/down and drawer open/close.
Transported by courier and would not accept DVD when received at the other
end - box must have been jarred. Try pushing the drawer in and it knocks the
spinner motor assembly which is in the up / play position. The repair manual
only says replace the DVD unit in this situation. Removed this sub-unit,
N78E3CBN no info found. Delatched the drawer and removed , turned cogs and Z
track etc until only the drawer motion cog moved with no movement of sledge
or Z-rack and reintroduced the tray and optical unit in eject position. Is
this a standard approach to this symptom for direct coupled ie no drive
bands? Seems to work now - but just temporary or fixed proper for normal
use? No cracked /broken cogs/racks or free-floating pieces found.
The drawer seems very flimsey, I assume it flexed and a guide peg got on the
wrong side of a rail. Common problem? with a recognised correction of
beefing up somehow?
beefing up somehow?
