tool for stripping wires without cutting them?
I plan to install a remote starter in my car. I'd like to buy a tool
to strip the wires, if its not too expensive. I have a set of plier-
like ones, where you insert the wire into the correct slot, squeeze
the handles, then pull the wire through, shedding the insulation.
But that is only for stripping the ends of wires. I'd like to be able
to strip wires 'inline', without cutting them. Is that what an
automatic stripper does? Like
http://www.radioshack.com/product/index.jsp?productId=2062786
or
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=42101
Or is there another tool? Thanks.
Meat Plow
or
http://www.wrcase.com/knives/pocket_knives/
#1 Offishul Ruiner of Usenet, March 2007
#1 Usenet Asshole, March 2007
#1 Bartlo Pset, March 13-24 2007
Pierre Salinger Memorial Hook, Line & Sinker, June 2004
COOSN-266-06-25794
H
Homer J Simpson
You can buy those in dollar stores.
Most of us use a pocket knife - carefully, so as to not nick the wire.
mark krawczuk
oh, you want to strip the wire without taking/cutting the conecctors of ,
?? buy a cigarette lighter, soften/melt the plastic and QUICKLY pul the
insulastion off with ya fingers.
mark k
Anthony Fremont
or
Those strippers are for stripping the end only. Their specialty is that
they "adjust" to the size of the wire automatically. This means they only
remove 10% of the strands along with the insulation. ;-)
Seriously, you should use a better connector instead. You don't want to
strip an inch of insulation off, you just want to displace enough insulation
to make a connection. Something like these:
http://www3.3m.com/catalog/us/en001...actors_3_0/command_AbcPageHandler/output_html
Try to find some that have a moisture resistant grease inside. This will
not only keep water out, but the air too.
Michael Kennedy
or
I use linemans plyers / dikes, but lots of people can't strip wire with
them.. They are my favorite tool for stripping wire.
http://cgi.ebay.com/vintage-KLEIN-S...03556914QQcategoryZ111614QQrdZ1QQcmdZViewItem
Dave Plowman (News)
or
Of these two the RS one is ideal for this purpose - provided you use the
correct size for the cable, and the sizes provided by the jaws cover the
cables in use.
I've got just about every cable stripper known to man and although the
automatic types sound like a good idea they simply don't match up to this
type for stripping with no chance of conductor damage - provided as I say
you use the correct 'notch' out of the four provided and make sure it's
aligned on the cable. If you're sloppy about this it makes a good cable
cutter. ;-) The snag is it needs more space to work than some other types.
This type is also of use as again won't damage the conductor but has to be
manually adjusted. Couldn't find it on the RS site, but most electricians
use them.
http://www.tlc-direct.co.uk/Products/VA237.html
Arfa Daily
insulation to make a connection. Something like these:
That's exactly the item that I was going to suggest as well. They are made
for the job of in-line splicing, and do it very well.
Arfa
Dave Plowman (News)
made for the job of in-line splicing, and do it very well.
And look like the bodge they are. ;-) You'll not find them used on a
maker's harness.
Anthony Fremont
maker's harness.
Do you think that stripping an inch of insulation in the middle of a run is
a better way to go? If so, you'll not be doing any wiring on my car. ;-)
Short of soldering, I can't think of anything more reliable than IDC type
crimp-ons. They're used all over the place in critcal applications. e.g.
computer data cables, network and telephone industry etc. Auto makers use
plenty of crimp-on pins too. :)
ampdoc
Arfa
90% of professional alarm installers use the T-Tap 3M connectors. They have
a great track record and work well, and are used because of the speed in
which they can be put in, as well as the fact you don't want to drop a hot
soldering iron in a brand new corvette seat :). If you use some 3M super 33
tape and wrap the harness for the alarm, and wrap your connections properly,
when you finish it looks enough like the car harness that a thief is hard
pressed to find the alarm wiring :)
Jammy
(Got stuck doing installs as well as repairs when I started in electronics)
Meat Plow
Thats what I used when I put in my last remote starter. It was a lot
of slow, careful work. I was hoping there was a tool that could do
this quickly and without risk of cutting the wire.
I don't know of any tool that would strip a section of wire other than at
the end. Why not use 3M splicers like everyone else? They don't require
anything except a pair of pliers. Way back when I started out in
electronics one of my first jobs was installing auto accessories. I used
those splicers all the time and can't recall every having a problem with
them.
Meat Plow
Heh, I just suggested these in a prior reply. I've used a ton of those
without any problems.
COOSN-266-06-25794
Dave Plowman (News)
is a better way to go? If so, you'll not be doing any wiring on my
car. ;-) Short of soldering, I can't think of anything more reliable
than IDC type crimp-ons. They're used all over the place in critcal
applications. e.g. computer data cables, network and telephone
industry etc. Auto makers use plenty of crimp-on pins too. :)
But they're not a crimp. Proper crimped connections are fine.
Dave Plowman (News)
And 90% of aftermarket alarms are a problem within a few years. ;-)
F
Franc Zabkar
or
I use several mentioned in this thread, including yours. I also use a
"T-Rex" for ribbon cable and such like:
http://www.sicom.co.nz//site/images/42904.jpg
- Franc Zabkar
