Hello,
I have built a circuit to drive 16 led strips with PWM using TLC5940 chip with 16 TIP120 transistors.
Each pin of the TLC is sinking 20mA, connected to the base of the TIP120 (NPN, my led strips are common anode), and I have added a 10K pull-up resistor connected to 5V. Everything is working fine, I was wondering if 10K is the right value, I have tried 2.2K and it 'seemed' to do the same. I don't know how to calculate the right value for the resistor, and if it has some impact on the brightness of the leds.
Sorry if I don't explain this right, I don't have a lot of experience.
Thank you in advance,
Philippe
Philippe
