tl431 calculations
Using a TL431 to limit a 29v source to about 5v.
I see I calculate the two divider resistors to set the vref.
There's one other resistor that limits the current.
Any suggestions how to determine that value?
There's a current limiting resistor before the voltage divider in the sample circuits. I don't know if that what you mean by Rsup.
Load current about 20-30mA.
The minimum current through a TL431 is around 0.5mA from memory, but let's make it 2mA.
Thus, there are three places for the current to go:
1) through the load (30ma)
2) through the tl431 (min 2mA)
3) through the voltage divider across the TL431.
The TL431 has a reference voltage of about 2.5V, so the voltage divider for 5V is simply 2 resistors of the same value. Let's use 10k.
So 5V across 20k is 0.25mA
The total current is 32.25mA.
The series resistor needs to drop no more than Vin - Vout at 32.25mA.
If we want the circuit to operate down to 10V input voltage, then the required series resistance is (10 - 5)/0.032225 = 155 ohms (let's say 150 ohms).
If the maximum input voltage can go up to 14V and the load is disconnected, then the current through the 431 will be ((14 - 5)/150) - 0.00025 = about 60mA and thus the dissipation of the TL431 will be 300mW and the series resistor will dissipate 0.54W
under these circumstances the 431 will probably need a heatsink, and the series resistor should be rated at 1W to be safe.
Change the figures to suit your application. OOPS I used 12V as your source voltage, so you'll have to recalculate anyway. do that and we'll check you got it right.
"The TL431 has a reference voltage of about 2.5V, so the voltage divider for 5V is simply 2 resistors of the same value. Let's use 10k."
If it's 10k each, then 1 x r1/r2=2.5v. Shouldn't it be a 20k and 10k, so 1 x r1/r2=5v?
Vout=Vref(1+R1/R2)
for R1=R2 you get
Vout=Vref*2=5V
So R1=R2=10k ohm is correct like steve suggested
Rsup is the series resistor .
In order to calculate it you need to know the following info.
Maxiload=Max load current (Not "about")
Miniload=Min load current (Not "about")
MaxVsup (non regulated voltage)
Min Vsup (non regulated voltage)
once you know the above
IakMin =1ma (from data sheet) ;
RsupMin=MinVsup/(IakMin+Maxiload+5/20K)
IakMax= 100ma (from data sheet);
The maximum AK current in the circuit is
Iakmax=MaxVsup/RsupMin should be smaller than 100ma
I see. The divider is calculated so there's always 2.5v at REF?
That sets the Vo, and the Rsup is for current..
