Timing circuit help needed
I
Ivan Vegvary
Installed car seat warmers into SWMBO's car. Key must be on for them to function. Would like to rewire in a way that I could preheat the seats priorto her use. 5 to 10 minutes would be sufficient. Ideally: Push remote control button from inside house (15 feet from car), seats circuit turns on for circa 5-10 minutes. If ignition is not started after 10 minutes, seatsturn off. If ignitions is started, seats remain energized.
Resources: Remote control door fob, Arduino Uno, very small knowledge of digital electronics.
Suggestions greatly appreciated.
Ivan Vegvary
P E Schoen
"Ivan Vegvary" wrote in message
prior to her use. 5 to 10 minutes would be sufficient. Ideally: Push
minutes, seats turn off. If ignitions is started, seats remain energized.
You could use a time delay relay with an interval function, such as:
http://www.newark.com/pdfs/datasheets/SE_Relays/TDRSOXP-12V.pdf
but it's about $66:
http://www.newark.com/magnecraft/tdrsoxp-12v/time-delay-relay-dpdt-10h-12vac/dp/10M6239
If you can get the Arduino to respond to the remote door fob, it could
easily turn on a relay for the time needed. You could use diode steering
logic to allow the seats to be warmed either from the Arduino (which would
be directly off the battery), or the ignition. You could also add a
temperature sensor to control the heat, and a battery voltage sensor that
would keep the heating turned off if battery voltage dropped below a safe
level.
Paul
I
Ivan Vegvary
Installed car seat warmers into SWMBO's car. Key must be on for them to function. Would like to rewire in a way that I could preheat the seats prior to her use. 5 to 10 minutes would be sufficient. Ideally: Push remotecontrol button from inside house (15 feet from car), seats circuit turns on for circa 5-10 minutes. If ignition is not started after 10 minutes, seats turn off. If ignitions is started, seats remain energized.
Resources: Remote control door fob, Arduino Uno, very small knowledge ofdigital electronics.
Ivan Vegvary
I
Ivan Vegvary
but it's about $66:
level.
Paul
Paul, thank you so much for your reply. It has given me ideas and direction. Thanks again.
Ivan Vegvary
