Help - timing and switching circuit needed
Steve Newport
Hello all,
I am trying to find out how to build (sorry am a relative amature) a
timing and switching circuit. The basics are as follows:
Operates off a 12v dc battery
operates (single pulse) up to eight 12v dc solenoids.
sequence of operation is set
timing between each operation could vary in the range 12-48 hours
Can anybody help?
chuck
Steve said:
Hello all,
Can anybody help?
Check this out, Google on what you don't
understand, and ask again if you need help.
Good luck, Steve.
Chuck
http://uk.geocities.com/ronj_1217/c4060s.html
Two Simple 24-Hour Timer Circuit Schematics
E
ehsjr
Steve said:
Hello all,
Can anybody help?
Do you mean that solenoid 1 operates, then 12-48 hours
later solenoid 2 operates, then 12-48 hours later
solenoid 3 operates, etc?
Ed
Steve Newport
Yep, a couple of places in the sequence more than one solenoid may
operate but essentialy yes.
Donald
Ok, a long duration sequencer.
What is the "single pulse" ??
Any microcontroller chip with a RTC (real time clock) chip and a relay
driver chip can do this.
Are you looking at "building this yourself" by,
a) buying computer/logic boards and programming them yourself.
b) building your computer/logic PCBs and soldering the chips down
yourself then programming them.
or
c) buying a complete system that can control relays with a "single pulse"
How much of "build it" are you interested in doing ??
donald
Steve Newport
or
donald
Sorry, the description I gave was a bit wooly. The solenoid acts to
open a small catch - all it needs is one pulse to make it pull. ie: No
need for a permanent current to be applied. Hope that makes sense.
Was hoping to do a complete self build but if there is something ready
made then why re0invent the wheel so to speak?
Was hpong that what I need would be some combination of a 555 chip and
relay etc. Wasn't imagining anything like programming as that would
probably be quite beyon my capabilities.
I could cope (just) with buying components and soldering them together
E
ehsjr
There's a kit than can be set up to give you a pulse
every ~22 hours (or less).
http://store.qkits.com/moreinfo.cfm/QK152
You would need to add two circuits: a 4017 counter to
advance to the next solenoid when the kit provides a
pulse, and a solenoid driver circuit that will provide
a pulse to the solenoid. We need to know a couple of
things. How long does the pulse to the solenoid have
to be, at a minimum? How much current does the solenoid
take? Can you build the two additional circuits without
using a kit?
Ed
Steve Newport
using a kit?
Ed
Thanks Ed. The solenoid I was looking to use can be seen at
http://www.islikersolenoids.co.uk/scripts/isliker/linear_type5.html
Not suggesting you look it up - just wanted to state it in case you
wanted to look. I have downloaded the technical data sheet but it
doesn't seem to give the details so I have emailed the company and
asked. I'll post back when I get a reply.
I understand what you have suggested (many thanks indeed) and it makes
sense. Whilst I am probably OK with the solenoid driver circuit; the
technical data sheet I downloaded gives me some examples and they seem
straight forward. However, the 4017 counter - I wouldn't know where to
start. Is it likely that a kit is available?
E
ehsjr
There is a kit CAT# AEC at Allelectronics
http://www.allelectronics.com/
It is an LED chaser kit - you would need to modify
it (simple - don't install the 555). As designed, a
555 runs as an astable. The output of the 555 clocks
the 4017 counter - the output of the counter drives
the LEDs. You would use the QK152 output to create
the clock pulse that advances the 4017 counter.
Connect teh QK152 output to pin 14 of the 4017.
You would also need to modify the QK152 to reset
itself when it reached the period you select so that
it starts timing all over again. (Mod described
below)
Here's how you could do it:
In the QK152 when the 4020 counter reaches a value of 8,
use that pulse to activate the solenoid driver. When the
count reaches the value equal to your period, use that
pulse to advance the 4017. The same pulse is used to
reset the 4020 to 0 (connect the reset pin, pin 11, to
the pin for the period you chose). The 4017 count is used
to energize a relay or bias a transistor on so that when
the solenoid driver pulse arrives ~ 8 seconds later, the
correct solenoid is fired.
QK152 mod: you need to connect pin 4 of the 555 to
pin 8 of the 555, and remove the connection from pin
4 of the 555 to the collector of Q1. The collector
of Q1 needs to remain connected to R7 if you wish
to use the transistor outputs for something. As mentioned
above, you need to connect the period output pin to
tyhe reset pin to set the 4020 to 0.
Ed
E
ehsjr
ehsjr said:
Steve Newport wrote:
Aargh! There was an error in my reply. I have modified the
reply, below, to correct the error. The good news is that it
will simplify things, and save needing a solenoid driver.
It is an LED chaser kit - you would need to modify it
(simple - don't install the 555). As designed, a 555
runs as an astable. The output of the 555 clocks the
CD4017 counter - the output of the counter drives the LEDs.
You would use the QK152 8192 output (4020 pin 3) to create
the clock pulse that advances the 4017 counter. Connect
the QK152 4020 pin 3 to pin 14 of the 4017 in the AEC kit.
In the QK152 when the 4020 counter reaches a value of 8192,
use that pulse to advance the 4017 in the AEC. The 4017 count
is used to bias a transistor on so that when the solenoid
driver relay pulse arrives ~ 8 miliseconds later, the correct
solenoid is fired.
AEC mod: omit 555 and LEDs. Remove existing connection to 4017
pin 15 and connect count N+1 output pin to pin 15, where N is
the number of solenoids. See the 4017 datasheet.
QK152 mod: you need to connect pin 4 of the 555 to pin 8 of
the 555, and remove the connection from pin 4 of the 555 to
the collector of Q1. The collector of Q1 needs to remain
connected to R7. Use the QK152 relay contact to connect + to
the solenoid. Partial schematic below.
QK152
Relay contact
+24 -----o---
^---o----+----+------+----+------+----+--}}----
[Sol1] [D1] [Sol2] [D2] [Sol3] [D3]
| |a | |a | |a
/c | |
4017 pin 3 --[R]--| NPN | |
\e | |
Gnd | |
/c |
4017 pin 2 ---------[R]-------| NPN |
\e |
Gnd |
/c
4017 pin 4 ---------[R]-------------------| NPN
\e
Gnd
Note that it assumes 24V solenoids. The relay contacts
in the QK152 can handle up to 10 amps. The transistors
have to be chosen to handle the solenoid current and may
need to be darlingtons or FETs. R should be at least 1K
Ed
Steve Newport
solenoid is fired.
QK152
Relay contact
+24 -----o---
| |a | |a | |a
/c | |
\e | |
Gnd | |
/c |
\e |
Gnd |
/c
\e
Gnd
Ed
Many thanks Ed, really appreciated. I will pull this together and have
a go.
jasen
google for 555+monostable
and 555+relay
If you'd asked in s.e.b I'd have posted you a schematic.
Bye.
Jasen
