Timer for CFLs?
Justin
Two things... Are there ant in wall switch timers that can be used for
CFLs?
What about receptacle timers that can be used with CFLs?
Something available at Lowes or Home Depot would be preferable.
If they ban incandescent how is that going to work? Is it a big deal to
make timers that can handle CFLs?
Charles
CFLs?
I use the receptacle times on my aquariums all the time, never gave it
a thought. I don't see why CFL would make any difference.
CFLs?
I have used two different Intermatic wall-switch timers on my front porch
light. The first one was electromechanical and the present one is
electronic. The electromechanical one drew a little bit of current
through the lamp when the lamp was off to run the timer motor, and some
CFLs didn't like this that much, as manifested by short life. Nothing
spectacular happened; the lamp just died in a couple of months as
opposed to lasting a year or more. The electronic one has an AAA
battery and a bistable relay; it doesn't draw any current through the
lamp and only draws significant current from the battery twice a day.
I haven't experienced short CFL life at all on this timer.
Probably almost any of them would work. The receptacle timer has a
direct connection to both sides of the AC line for the timer motor, and
so doesn't have to draw any current through the lamp when the lamp is
off. The electromechanical ones all use a simple contact closure to
switch the load, which is exactly the same thing as a normal toggle
switch.
About as well as banning booze did.
Matt Roberds
Justin
I saw two at Lowe's - one clearly say no ballast or fluorescent.
The other didn't say no fluorescent. I'll jot down the model number and
contact the manufacturer. I doubt the kids they have working there will
know.
switch.
I tried one internatic with the pegs and it was making a bussing noice -
almost like there was some internal arcing going on.
I see a business opportunity...
TKM
Victor Roberts said:
Yes, there are some timers that will work with CFLs, but you
may have to test a few to find ones that work.
There are two issues:
1) If the times has only two wire connections (and does not
have its own battery power supply) it need to draw some
small amount of power through the lamp load. This is not a
problem with incandescent lamps but will cause CFLs to pulse
on for short periods at a slow rate - which will destroy the
lamps while it drives you nuts. This problem can be solved
with a small fixed load across the lamp, but this is not a
normal consumer fix.
People will make wall timers that work with CFLs. .
And dimmers that dim nicely too, no doubt.
I'd also like to see a CFL that mimics a dimming incandescent where the
spectral output of the light shifts toward red as the light output goes
down. Yes, I know that's going to be difficult; so, perhaps, we'll have to
wait for that feature in the LED versions.
Terry McGowan
I wonder how hard it would be to design one that stores energy in a
rechargeable battery, charges it only when the light is on via the
current going through to power the light, and runs the electronic
timer from that battery when the light is off.
| The electronic one has an AAA battery and a bistable relay; it
| doesn't draw any current through the lamp and only draws significant
a rechargeable battery, charges it only when the light is on via the
This is how many older setback thermostats worked; they drew current
through the fan relay coil in the furnance (relay off) to operate the
clock motor and charge a small NiCd battery. When the fan relay was
on, the clock motor was powered by the battery.
The electronic timer I have switches twice a day (off in the morning,
on in the evening) and gets a year or so out of an AAA alkaline battery,
so I'm happy with the battery life.
One problem with using a rechargeable battery in this application, even
in a circuit that is designed for it, is that some chemistries (NiMH in
particular) have a rather high self-discharge rate, on the order of 1%
of remaining capacity a day. If the lamp was off for a long period of
time - manually shut off by the user, or burned out - the battery could
discharge fairly quickly.
Matt Roberds
I'd rather someone make a dimming incandescent that keeps the same color
throughout the range. Seriously. Yeah, I know that will be hard. That's
why I suggested the idea of lots of small low voltage halogen bulbs that
are selectively powered on or off as desired.
Justin
People will make wall times that work with CFLs. .
What about this one?
Intermatic ST01CL
http://img169.imageshack.us/my.php?image=image014co6.jpg
Justin said:
This appears to be an updated version of the one that I am using to
switch the CFL on my front porch. The manufacturer's page is at
http://www.intermatic.com/Default.asp?action=prod&pid=9472&did=5&cid=43&sid=112
and that page claims "Controls lighting including fluorescent" and
gives a ballast rating, both of which are good indications that it can
switch CFLs without difficulty. Looking at the instruction manual, one
strike against this timer is that it uses a goofball battery (CR2, 3
volt); mine uses a normal AAA 1.5 volt battery.
Matt Roberds
I'm suggesting that the battery be charged during the _on_ times, and
the clock run from the battery during _off_ times. This would not work
for a motor clock. But a CMOS clock could do it.
Or in the case I'm suggesting, the device under control not be turned on
for a very long time. It would need to have a manual-on button _and_ do
the charge during manual on. Then you could simply turn the device on
via the manual on button (closes the circuit long enough to get enough
current to turn the solid state switch on).
TKM
I don't think any CFL will give you the desired color shift.
LEDs can, but I have yet to find a company that understands
that they should! Everyone seems to brag about NO color
change with dimming.
Well, I thought it would be worth mentioning especially now that LLF has
developed that clever color balance circuitry to keep their LL6 LED
downlight color constant. And, such features are needed as high-efficiency
lighting makes its way into residential applications.
Terry McGowan
| IMHO, we can pretty much kiss incandescent technology (as we know it today)
| goodbye.
The black market won't. There will still be demand for good quality light.
Until the other technologies can match it, the market is there.
