Good Day,
I have a Thrustmaster T300 racing wheel. It won't detect the pedals. Looking further, it appears there is no 5V to the pedals from the pcb. Attached is a pic of the suspect area (I found the pic on this forum. It is a clearer pic than I can take.) I think they are diodes. Marked on the board as esd1(?) the rest of it is covered by the sticker. All marked with an ESD are the same. I have one that is open in both directions the others are open one way, continuity the other way. It is the one directly above the red wire which is 5vdc to the pedal and appears to be the only connection to the pin.. The part is marked with an AB. Any ideas what I can use to replace it to test?
Thanks in advance.
Thanks in advance.
