Joel Kolstad
Say Jim (or anyone else),
The resistor you add in your gyrator to "tame the peaking" related to the
finite GBW of the op-amps... I'd like to understand and/or derive the value
you use, R=2/(2*pi*GBW*C). Any pointers on how do go about doing so? I'm
thinking that if I go through the math for a regular integrator using an
op-amp with finite gain and a single pole (i.e., dominant pole assumption),
the resistor you add will have some "obvious" effect on the transfer
function that causes it to move somewhat closer to 1/sC.
I know at one time I read one of your comments about this resistor to the
effect that its usage was well known?
Thanks,
---Joel Kolstad
Thanks,
---Joel Kolstad
