Platforms
Content
Very nice Hevans! Thank you for sharing.It is a cold-cathode neon trigger (thyratron) lamp. I used one of these in the mid 1960s to build a full break-in keyer for my home-brew 80m Novice radio transmitter. The device was used to short my Heathkit SB-301 receiver antenna input each time the transmitter was keyed on, thus protecting the receiver from my mighty 70 watt RF output. Worked great! Unfortunately, at that time hardly any amateur radio operators were equipped for (or even knew about) full break-in keying or QSK as it is called. I liked it because I could receive transmissions from other hams in between Morse code character transmissions by me. During the time I was active as a Novice I don't recall "working" any ham who had QSK or knew about it. Today, everyone can use it. Most newer ham "rigs" are equipped for QSK operation even if the appliance operator isn't aware of it. See attached datasheet for an example type of this device.
I wish I could find some more of these to play with. The original that I used was a NE-xx where xx is now forgotten. Google has been of no help so far, except to eventually turn up the British CV2486 datasheet, no doubt obsolete and unobtainable now.Very nice Hevans! Thank you for sharing.
Great! Can you provide a part number or a source of supply? Here is a datasheet for a Russian version.Bulbs like yours are frequently wired across the telephone line connectors on alarm systems to shunt high voltage transients to ground to protect the circuitry.
Uses NE-77 neon lamp, which is similar to NE-2 but has third electrode for triggering. When person touches metal sensor plate of switch, AC voltage picked up by body is applied to trigger electrode of neon, making it fire and energize 5000-ohm relay K1 (Potter & Brumfield RS5D or equivalent). Relay remains energized until S2 is opened to reset circuit. Adjust R1 so voltage applied to center electrode of V1 is just below trigger point.-J. P. Shields, How to Build Proximity Detectors & Metal Locators, Howard W.Sams, Indianapolis, IN, 2nd Ed., 1972, p 52-55.
Like a kid in a candy storeGreat! Can you provide a part number or a source of supply? Here is a datasheet for a Russian version.
