G
George Herold
There's been a design for a little transistor/diode temp. sensor
floating around in my head.
In one version, there'll be a direct ground connection.
I wanted to have an electrically floating version too.
I want to try a circuit on flex (kapton).
Using the kapton as the insulator looks like a good idea.
But the thermal conductivity 'stinks'. (~0.15 W/m-K)
So driving home tonight I was thinking about using
an Al2O3 washer instead.
"What's the thermal cond. I said to myself, 100, 50 W/m-K?"
Googleing Al2O3, thermal conductivity Coorstek, I found this,
http://www.coorstek.com/resource-library/library/8510-1042_ceramic_material_properties.pdf
(I might have to print it out and pin it up.)
So for this application I need a 'decent' electrical insulator.
Which looks to rule out all the carbide's.
But what about the direct sintered SiC?
And then what about Aluminum and Silicon Nitrides?
Has any one used those?
I'm looking for a little thin insulating washer, that will go from
77K to 400K. (Maybe 500?).
A hole for a 2-56 screw.
George H.
George H.
