The Perfect Gift: A Tool Box
F
Fred McKenzie
Most everyone has a screwdriver or two laying around the house, but not
everyone has a minimum collection stored in a tool box. If you know a
young person graduating from high school, a single relative, or even
yourself, a tool box with a minimum complement of tools may be the perfect
gift.
Based on my own experience, the BASIC TOOL BOX should include:
A plastic or metal box such as the 13² plastic box from Walmart or the 14²
plastic box from Lowes. The box should have a secure latch that won¹t
come open when picked up.
#1 Philips screwdriver
#2 Philips screwdriver
1/8² Flat blade screwdriver
1/4² Flat blade screwdriver
Standard pair of slip-joint pliers with insulated handle
Diagonal cutters with insulated handle
Long nose pliers with side cutter and insulated handle
Small claw hammer such as Sears 3805 - 7 oz.
Depending on your knowledge of the individual¹s needs and the size of the
box, additional items might include:
Full-size hammer
Crowbar or pry-lever
Flashlight
Tire pressure gauge(s)
Pocket knife & sharpening stone
Soldering iron & solder & soldering braid
Digital multimeter
Set of nut drivers
Set of Allen wrenches
Set of Torx drivers
You get the idea!
73, Fred, K4DII
H
Highland Ham
What about Posidrive screwdrivers ? These are similar to Philips type of
screwdrivers but have additional 'notches' (if that is the correct word)
for better grip . The relevant screw heads are accordingly.
Frank , GM0CSZ / KN6WH
PS Most screws used in the UK are now of the Posidrive type.
jakdedert
gift.
Full-size hammer
Flashlight
Digital multimeter
Set of nut drivers
Set of Torx drivers
You get the idea!
73, Fred, K4DII
Dunno why it didn't occur to me...thankfully it 'did' occur to my wife:
Bought almost the exact (above) setup for my prospective son-in-law
for Christmas. He's mechanically dis-inclined. We're gonna fix that.
Can't have a s-in-l who can't fix stuff....
jak
Jerry G.
And... You plan to work on SMD circuit boards with this!!!
Jerry G.
Jerry G.
Jerry G.
F
Fred McKenzie
Frank-
I've heard of Posidrive. I think they are used in an old Hewlett Packard
counter I have. However, the tool dealers I asked had never heard of
them. I ended up using a common Phillips driver for my counter.
Certainly Posidrive would be a better choice where they are more commonly used.
Fred
Michael A. Terrell
Jerry G.
I see that you still have reading comprehension problems, Jerry.
Anyway, no one in their right mind would try to cram a good SMD rework
station into any toobox. There is no way I would let anyone shove a
stereo microscope into a toolbox.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Mr Fed UP
Heh heh dont forget the asprin and $50 for the headache and one
tool you'll always have to go get for each job. And a 6" or 8"
knuckle buistin adjustable wrench. LOL
Good luck
K4TWO Gary
Roy Lewallen
I'd consider looking for some other tool dealers to do business with.
Pozidriv (a registered trademark of Phillips Screw Co.) screws and
drivers are very common, sold by just about every tool company from
Snap-on through Stanley to Sears.
Tektronix used Pozidriv screws exclusively for many years, until they
converted over to Torx. A standard Phillips bit fits poorly in a
Pozidriv screw, making it really easy to chew up the screw with this
combination. Any decent toolbox should include some Pozidriv drivers or
bits.
Roy Lewallen, W7EL
Michael A. Terrell
Don't forget a 4" pipe wrench for those tight spots! It has been a
real life saver to remove broken studs and broken pieces of bolts. I
have one made by Rigid.
BTW, you won't bust your knuckles if you buy a real wrench. 8" is too
short to get a good grip on things. I have a 12" and a 14" "New Britain"
adjustable, along with a 4" Xcelite in my electronics tools.
The only tools I usually have to buy these days are new ones to
replace what walks away. :(
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Silfax
<snip a bunch of good stuff>
6" and 12" adjustable wench
12' tape measure (25' would be better)
mechanical pencil, extra leads and a small notepad
Silfax
oops I meant wrench, although a flexible wench might not be a bad idea
either (but she should be bigger than 12 inches....)
jakdedert
A common problem is to turn the adjustable wrench around the *wrong
way*! I've had people argue that there is no wrong orientation for the
common 'C' (Crescent) wrench, but there most certainly is. Do it wrong
and you'll be fine 75% of the time; but that one time when you need it
to really bite--and you do it wrong--*you* are the one who gets bitten.
Boy Howdy! I recently moved my office/shop and salvaged the buildings
on the property at the same time. I'm still trying to find all my tools....
jak
Joel Kolstad
Roy,
converted over to Torx. A standard Phillips bit fits poorly in a Pozidriv
screw, making it really easy to chew up the screw with this combination.
How well does it work the other way around -- using Pozidriv screwdrivers on
"regular old" Phillips-head screws?
Michael A. Terrell
Yes, most people seem to use it backwards where the stress is against
the front of the movable jaw, rather than the back where its supposed to
be. It doesn't matter if the item is fairly loose, but when you really
need the torque, it needs to be turned the right way. Maybe they need
to cast notches for your fingers to show people the right way to use it!
jak
I'm trying to but my shop back together. I haven't really worked in
the shop since the middle of 2001, right before I got sick and lost my
job. Now, its been five years and two years of hurricanes that made the
mess even worse. Some squirrels nested in the building and chewed the
cords off of everything in sight. I had to put rat poison in there to
kill them all. I'm missing two cordless drills, two surface grinders
and enough hand tools to fill a couple large toolboxes. Since I no
longer do any work away from home I have started hanging what is left on
pegboard over the different workbenches.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Bill Turner
ORIGINAL MESSAGE:
or bits.
*********** REPLY SEPARATOR ***********
The flutes on a Phillips bit are tapered; on a Pozidrive they are
parallel. In many cases you can use either bit on the other, but if
available, use the correct one.
A Phillips bit can "lever" itself out due to the taper, where a
Pozidrive will not.
Bill, W6WRT
ex Tektronix employee
Roy Lewallen
Joel said:
Roy,
In my experience, it works better than using a Phillips driver on a
Pozidriv screw. But it still doesn't fit really well.
Roy Lewallen
F
Fred McKenzie
OK Guys! I've done some more checking, and still can't find a store that
sells Posidrive or Pozidrive. I have one lead to a specialty tool store
across the state, but the local Ace, Sears and Lowes don't carry either
the screws or the drivers.
I can see where the Posidrive may be used in some electronic equipment,
but all of the screws in the hinges in my house, as well as the screws
holding the locks on the doors, are definitely Phillips. Are Posidrive
screws used for those applications in other countries?
I can see now that my original list should have stopped without the
additional items. The purpose was to define a really BASIC set of tools
for use around the home!
Fred
Roy Lewallen
There's sure no problem finding mail order sources:
http://www.stanleytools.com/default.asp?TYPE=CATEGORY&CATEGORY=HT+PZDRV+AND+MULTI+SDRVRS
http://www.vermontamerican.com/products/subcategorybrowse.htm?G=157721
http://buy1.snapon.com/catalog/search_keyword.asp?keyword=POZIDRIV
http://www.aaronsscrewdrivers.com/PowerBits.htm
http://www.sears.com/sr/javasr/prod...ical=TOOL&pid=00973645000&subcat=Screwdrivers
The real advantage of Pozidriv is in applications where something is
mass produced with the screws put in by power drivers, so they're fairly
common in manufactured goods. I was really directing my earlier comment
that every toolbox should have some Posidriv bits or drivers to people
doing any kind of work on electronic equipment or other kinds of
manufactured goods. Posidriv tools probably wouldn't be of much use for
most household repairs, so wouldn't be appropriate for a very basic
household tool box. The same goes for Torx.
You can identify Pozidriv screws by a ding in between the slots. There's
a good picture at http://www.aaronsscrewdrivers.com/PowerBits.htm.
Roy Lewallen, W7EL
Dave Platt
I haven't seen complete Pozidrive drivers anywhere around here, but
Orchard Supply (local hardware outlet) has Pozidrive bits in several
sizes, which will go into the usual magnetic-hex-socket driver
handles. In fact, just yesterday I glanced over their $2.99 "17 bits
in a small carrying case" assortment by the cash register, and found
that it contains 3 Phillips and 3 similarly-sized Pozidrive bits.
