I saw a video on YT that showed how to test a small transformer such as a common SMPS transformer using a powered wall wort AC adapter.
I have this transformer......and when I place it on top of an AC adapter it does not respond to the magnetic flux when I connect a VOM, set to AC voltage with (clip on leads) on pins 10 & 11 or on pins 2 & 3 or 4 & 5. Does that mean it is bad? Shouldn't any transformer like this respond to magnetic flux?
In the video his transformer responds nicely and you can determine the Primary from the Secondary sides. His also reveals the turns ratio. It is quite amazing. Mine won't give up ANY secrets. It's like a dead blob.
