I found two archived threads about the notorious yellow glue, often used on power supply boards manufactured in Asia, that eventually turns brown and conductive:
https://www.electronicspoint.com/threads/that-awful-yellow-glue-on-circuit-boards.61364/
https://www.electronicspoint.com/threads/yellow-glue-strikes-again.238455/
I recently repaired the power supply board of my Samsung 24" LCD monitor (purchased new in 2008) by using an exacto knife to saw some grooves in the glue, which was a light tan color. There'd been an electric arc underneath a small transformer. The glue covered that side of the transformer and some neighboring components, so I sawed some "fire breaks" in the glue so its undesirable conductivity would no longer connect any of those neighboring components to the transformer or each other. That appears to have eliminated the arc and the monitor works again. Unfortunately, there's a lot of glue elsewhere on the board, mostly yellow or light tan, which I assume are ticking time bombs. So I'm wondering how to remove the rest of the glue without laboring for days and with minimal risk of damaging the glued components.
Some threads at Badcaps.net say to soak the glue in isopropyl alcohol, but I don't know if that will work before the glue degrades and turns brown. In the first archived thread linked above, the last message (written by Ray in 2005) contains the following: "You can't get it off until it starts discoloring. I've tried." Unfortunately, Ray didn't say how he'd tried.
I tried applying 91% isopropyl alcohol (recommended at http://www.badcaps.net/forum/showthread.php?t=34692) with a q-tip to another patch of glue for a few minutes but that didn't help me scrape it off with an exacto knife.
How about using a moto-tool with a small filing bit to remove the glue? I'm wondering whether to buy and try the following one at Amazon, which costs about $24:
Dremel 7300-N/8 MiniMite 4.8-Volt Cordless Two-Speed Rotary Tool
https://www.amazon.com/gp/product/B003TU0XFU
Any suggestions? Thanks in advance!
