panfilero
I am purchasing a Nand-Flash memory chip.... just stand alone only
flash... not a microcontroller or anything. I was wondering if anyone
knew of any interfaces or test boards (maybe they are called flash
controllers? I'm not sure) that I could use to test the memory...
basically I will write a little code to read and write, and then check
that the memory is ok. So far I have found this:
http://download.micron.com/pdf/technotes/nand/tn2905.pdf which seems
about right, except that I would prefer to have an ethernet output
instead of rs-232. Does anyone know of any other boards like this? Or
if there is a way to convert RS232 to Ethernet?
