Test bench power supply
Found this power supply article on nuts and volts from march 2007 and I would like to build one:
I'm having a bit of an issue to find some parts like the transformers, I was looking to find exactly the same parts.
page47image12584
PARTS LIST
0-20 VOLT BOARDS DESCRIPTION
❑T1 120V primary, dual 44V center tap secondaries @ 1.5A
❑ D1,2 3A, 100 PIV
❑ D3,4,5,6 1N4002
❑ C1 4700 ìF/35V *
❑ C2 100 ìF/35V *
❑ C3 0.22 ìF
❑ C4 10 ìF/35V
❑ C5 22 ìF/35V
❑ C6 0.1 ìF
❑ R1 0.1Ù 1% 3W
❑ R2 16Ù
❑ R3 750K
❑ R4 2.7K
❑ R5 12K *
❑ R6 240Ù 1%
❑ R7 100K
❑ R8 910Ù
❑ P1 500Ù
❑ P2 5K
❑ P3 200K
❑ P4 200Ù (Mouser #531-PT10V-200; $0.42)
❑ Z1 1.25 volts reference (Mouser #511-TS821A1Z; $0.64)
❑ IC1 LM317K (Mouser #511-LM317K; $2.10)
FIVE VOLT SUPPLIES BOARD
❑T2 120V primary, 9V secondary@ 1.5A
❑T3,T4 120V primary, dual 9V@ 65 mA secondaries
❑ C1 4700 ìF/16V
❑ C2 10 ìF/16V
❑ C3,5,7,9,11 0.1 ìF
❑ C4,6,8,10 47 ìF/16V
❑ BR1 2A, 100 PIV
❑ D1,2,3,4 1N4002
❑ IC5 7805
❑ IC1,2,3,4 78L05
MISCELLANEOUS
❑ S1 SPST toggle switch
❑ S2 4PST toggle switch
❑ Panel Meters 200.0 mV
The first one on the list I have a hard time to find one with the exact same specs
"T1 120V primary, dual 44V center tap secondaries @ 1.5A"
If you do find such a transformer, it will probably cost you more than buying a complete bench power supply.
Bob
Actually I looked, and dual supplies do not come that cheap.
I think your best bet would be to get a toroid core of the appropriate size and wind your own transformer.
Bob
I found a few Chinese power supplies on eBay rating 30v for $33 free shipping ---from China :) or they are really bad or they are really cheap
Bob
When I was a teenager I used to build my own transformers, good times, everything electronic was expensive so we had to improvise.
