Tesla coil components
Hello, I want to make a tesla coil but I can't make it myself based on the videos I watch on youtube so I want to ask how to make a musical tesla coil.
I have myself a coil of copper wire with
+Coil length (wired part only): 60 cm
+Wire diameter: 0.15 mm
+Coil outer diameter (wire part only): 27mm
+I don't remember the number of turns maybe all of the above can help me
I want to make my tesla coil can output a spark 3 inches long and use 12v DC
and the wire outside, I haven't done it yet. I want it to be customizable based on the above parameters
Edit:
I want to know what the circuit looks like and how many components I needed to create the circuit to make it work. Thank you
There are a number of kits available. Would you consider a kit?
Otherwise google for it, you will probablu find some non-youtube links.
I think the main key to success, as in many thingsm is look beyond youtube :)
You should read and then re-read those comments about high voltages and how they can be dangerous.
This project, in link below, does not help much for how to build it, but take a look at the second image down of how one sane university thought tesla coils should be safely used.
https://www.rnz.co.nz/national/prog...ic-for-tesla-coils-and-robotic-bass-and-drums
Yep, the whole thing in a Faraday cage.
I got lots of hits on just simple searches tesla coil musical diy OR instructable OR hackaday, ....
https://www.instructables.com/How-To-Make-A-Musical-Solid-State-Tesla-Coil-SSTC/
https://www.instructables.com/Build-a-Musical-Tesla-Coil-like-a-Pro/
https://onlinelibrary.wiley.com/doi/full/10.1002/ecj.12196
