Mat Nieuwenhoven
My Tek 547 stopped working (no light on the screen). All voltages were OK
except the CRT voltages. These are generated by a 6AU5 oscillator, which
didn't oscillate. Measuring with a sine on the grid and a 1K resistor in the
anode, I measured below 3mA/V . A replacement tube has 6.5 mA/V, and
oscillates again, but at 800 kHz instead of 50 kHz (as per manual) and with
much too low voltages produced. The 2nd grid was at 130V, should be 90 per
manual. Dropping it with an additional resistor to 90V made the produced
voltages even smaller.
I think the high frequency could be the main cause of the low voltages. I
believe frequency is determined mainly by the transformer and a 1 nF C
between anode and 1st grid of the 6AU5. But soldering a 100 pF C over the 1n
one made no difference in frequency, I would have expected a 10% drop. Using
a larger parallel one like 1 nF stops the oscillation.
Using another scope, I do see undistorted sines on the secondary windings.
Because my 547 uses semiconductor diodes (BY711) for the high voltage (a
mod), I do get secondary voltages, but much too low like 500V for the tube
EHT instead of 8 kV .
What can cause this high oscillating frequency? What is wrong and how can I
fix it? Could this be a faulty transformer (although I still see secondary
voltages)?
Thanks, Mat Nieuwenhoven
voltages)?
