Tek 455
Asimov
A friend emptying his closet sent me a Tek 455 that was previously given
to him in turn.
From a cursory visual inspection, all the boards seem intact and clean,
however I found the crt & graticule was missing... pretty hard to miss!
So I'm wondering if a crt is available used or NOS and what it may cost?
Or even simply if it's economically worthwhile?
Any comment(s) appreciated...
Asimov
.... Dunno if we'll get that past the CSA und UL 'owever.
Jim Yanik
to him in turn.
Economically,it depends on what the replacement CRT costs.I doubt you will
find a NOS CRT,it's long odds.Most likely you will have to find a parts
scope to cannabalize.
455's weren't the greatest TEK scope, but they were OK,IIRC,50Mhz
BW.Supposed to be a 'ruggedized' portable,but the plastic 'chassis'
flexed,and the connectors for the side modules were problematic,the tin
plated ones were replaced by gold,IIRC.Also,the vertical hybrid tended to
develop 'jitter'.(black pin-type heatsink IC-hybrid in vert module)
Asimov
"Jim Yanik" bravely wrote to "All" (18 Aug 03 15:46:29)
--- on the topic of "Re: Tek 455"
to him in turn.
JY> Economically,it depends on what the replacement CRT costs.I doubt you
JY> will find a NOS CRT,it's long odds.Most likely you will have to find a
JY> parts scope to cannabalize.
The crt shield is missing too. Just wondering if the scope wasn't
cannibalized of its crt for a better scope. Might this then mean the crt
may be a common part to the 45x line or exclusive to the 455? Either way
would you know what part # should I look out for?
JY> 455's weren't the greatest TEK scope, but they were OK,IIRC,50Mhz BW.
Makes sense, the sweep timing goes to 0.05us or maybe better with the
x10 mag.
JY> Supposed to be a 'ruggedized' portable,but the plastic 'chassis'
JY> flexed,and the connectors for the side modules were problematic,the
JY> tin plated ones were replaced by gold,IIRC.
Okay, they are all gold connections alright. I can see what you mean,
they could have used a 2nd lower frame from front to back to keep the
main board from flexing.
JY> Also,the vertical hybrid
JY> tended to develop 'jitter'.(black pin-type heatsink IC-hybrid in vert
JY> module)
Right, the large heatsinked affair in the middle of the vertical board.
Do you recall if the jitter problem was the external solder aging or
the hybrid's connections inside the package? Maybe a bigger heatsink?
Asimov
.... I worked hard to attach the electrodes to it.
Jim Yanik
I saw some CRT's on ebay the other day I think and also try
torontosurplus I think they had some on their site.
You also need to make sure all other hardware to go with the CRT is
there.
Might be cheaper to buy a scrapper on ebay or one of the auction sites
to take parts from.
Manuals do appear on ebay once in a while from $10-70, being its a tek
it will have everything you need it in it, operating instructions,
service and calibration, and complete parts and schematics.
REMOVE the NOCRAP in my address to reply.
No all TEK manuals are complete service manuals.
Some models have an operator's manual AND a service manual,and TDS and THS
series manuals have NO schematics or component parts lists.(Module exchange
service only)
Michael A. Terrell
Asimov said:
to him in turn.
Asimov
I have a Tektronix CRT and Shield.
The CRT part# is 154-0531-00
The shield part# is 337-1021-01
I believe they are from a 561 rack mount scope I scrapped for the
high voltage supply to fix a portable scope. I also have the power
transformer from the same scope.
The Power Transformer part# is 120-0575-00
Jim, do you have a manual to see if these will work for him?
Asimov
"Michael A. Terrell" bravely wrote to "All" (19 Aug 03 04:49:24)
Saved your part #'s until a determination of compatibility can be made.
Thanks!
MAT> From: "Michael A. Terrell" <[email protected]>
MAT> I have a Tektronix CRT and Shield.
MAT> The CRT part# is 154-0531-00
MAT> The shield part# is 337-1021-01
MAT> I believe they are from a 561 rack mount scope I scrapped for the
MAT> high voltage supply to fix a portable scope. I also have the power
MAT> transformer from the same scope.
MAT> The Power Transformer part# is 120-0575-00
MAT> Jim, do you have a manual to see if these will work for him?
MAT> --
MAT> Michael A. Terrell
MAT> Central Florida
Jim Yanik
you JY> will find a NOS CRT,it's long odds.Most likely you will have
to find a JY> parts scope to cannabalize.
crt may be a common part to the 45x line or exclusive to the 455?
Either way would you know what part # should I look out for?
Sorry,I can't recall specific CRT p/n's.
BW.
x10 mag.
problematic,the JY> tin plated ones were replaced by gold,IIRC.
vert JY> module)
board. Do you recall if the jitter problem was the external solder
aging or the hybrid's connections inside the package? Maybe a bigger
heatsink?
Problems with the hybrid itself.Bad IC die,IIRC.
Asimov
I suspect that a 465 tube would fit except for the anode lead maybe not
being long enough.Might be the same tube.You'd have to check both manuals
for that.TEK even used 465 tubes in T922/932/35,I believe,with a change in
the anode connector(to a spade connector and a silicone boot).
Thomas P. Gootee
Asimov said:
to him in turn.
Asimov
There is a Tek CRT-to-Instrument (and vice versa) cross-reference at:
http://www.reprise.com/host/tektronix/reference/crt.asp
You can use it to find out which other models used the same CRT, so
you can pick up a parts scope to cannibalize.
You can also check to see if Walter has one in stock, here:
http://www.sphere.bc.ca/test/tek1.html
Good luck!
Regards,
Tom Gootee
http://www.fullnet.com/u/tomg
