These questions are not geared toward any particular circuit, but these issues come uop from time to time, and I am wondering how people proceed:
1. I've built some circuits where a whole bunch of wires, (let;'s say 20 wires), all are to connect to a ground, or to a pin on another component. Any tips on how to deal with this while j=keeping the project tidy? For example, i had a project in which I had about 20 very thin wires (magnet wires) that needed to come together before going to another component pin. I kept bunching the enfs of the 20 wires to one another and soon ended up with an 1/8" diameter bundle of wires, that i attached a single wire tio, and ran that to the other component. Any best practices on this?
2. Similar to the above, I once had about 8 wires running to the ground (-) terminal. I kept wrapping each around the pin from the negative connector. The pin from the negative connector ended up having several wires wrapped around it, similar to if you wrapped a rope around the base of a pole. Is there a better way?
Thank-you
Thank-you
