I have been working on this receiver for a while now. I bought it from ebay as damaged/ for parts status. I replaced a couple
of transistors and I also replaced to two main drivers.
When I got the receiver only one channel was working and I tested some voltage nodes on the main Darlington Power Transistor for the left and the right channel. One of the Darlington channels had high voltage(15 volts approx.) readings while the other Darlington Power Transistor measured in 20 mV.
Unfortunately I had to make pilot holes with a fine wire drill bit to identify the solder side of the pcb board to unsolder and replace
the correct component which at the time was measured as being dysfunctional with the DMM.
I was able to correctly to replace the dysfunctional components but severed some of the traces with the bit. I decided to solder some jumpers to bypass the severed traces. Just recently I was testing the traces and one of them was contacting a node with was accidently made.
I believe this might have been the cause of the sparks while testing with a volt meter but I am not exactly sure.
