I sure hope it's not the MCU alone because that would spell trouble.
It sounds familiar. I've looked at these 'low power' ARM chips,
noticed that many seem to average 20-50mA, with the lower figure only
on a good day and many requiring more. It was NOT a shock to me to
see 120mA with ARMs. In fact, I'm just fine with that. But when the
OP writes, "I'm making a mcu based device which i want to be very
small and low cost" and then out the other side of the mouth says
"only 120mA" then I'm truly wondering.
One of the BIG tradeoffs is power __AND__ heat. And by the time you
get anywhere near 120mA, you've often got both problems in spades.
It's a fundamentally different domain.
I guess that's why I just went _white_ when I read those figures and
the OP's language in the same context. The only way 120mA is a
little, these days, is if you are used to x86 processors running at
GHz and requiring multiple power supply rails to help contain heat
problems better.
If you live in that world, I can see it. But that sure isn't MY
embedded world perspective. I consider moving into the 120mA domain
as being akin to a "damn-the-torpedoes, devil-may-care" world. At
that point, you are already spending dollars, not pennies, and have
board room to spare. And if you are chugging 120mA, you NEED space,
anyway.
Often there are other things like ADCs, analog stuff etc. 120mA is
really a piece of cake from a power converter point of view. After all,
that's only 600mW if his VCC is 5V. Low enough for an energy star
Hehe. Yeah. If we are talking washing machines, 120mA is no problem.
But room isn't a problem, then, either. There's always a corner, plus
one HUGE heat sink, too.
Michael may have to go with a SEPIC if he wants the FET to switch to GND
but that's not a big deal either, just two parts more. Since the advent
of PoE he's got plenty of options.
I'd recommend that Michael rethink 120mA. I mean, jeeez! If you
nearing a watt already, with overhead, you need space and you expect
to spend something on the power supply, too. Or some serious, crafted
time. Or both.
Almost two decades ago, I was worrying over a thermal cooling stack
with two Peltier stages and the bottom stage was consuming half a
watt. I was worried about that much heat. And the tiny micro device
plus analog circuits at the top was burning some 30mW. Now that's the
kind of thing you get with 120mA! 2-stage Peltier coolers AND a
micro. 20 years ago.
This is crazy-making to think about 120mA! Yeah, if you are making an
iPhone or internet interface device with RF and all. I mean, you need
to actually broadcast maybe 1/4 watt or so. So yeah. But "I'm making
a mcu based device which i want to be very small and low cost?"
The OP and I must come from different universes!
Jon
