Switchable Cathode Bypass Capacitor for a Tube amp
Hi All,
I am building a simple tube amp using ECC83, I read that the value of the Cathode Bypass Capacitor can have an influence on gain at different frequencies and headroom. Would it be possible to build in a switch so that I can switch between different capicitors and a a consequence produce fully / partially / un - bypassed effect . If so would attached circuit do the job ?
Many thanks
Jim
  • cathode-bypass-capacitor-selection-circuit.pdf
Harald Kapp
That should be possible, although I'm in no position to judge the effect.
I suggest you put the switch on the cathode side of the capacitor.
The 1uF capacitor will give a turnover frequency of about 100Hz, the 2uF capacitor about 50Hz. I think the gain will rise as the frequency rises and be limited to about 10 times the basic amplifier.
If you wish to reduce the gain and improve linearity with a constant gain, then you can put a resistor in series with a large capacitor.
CDRIVE
Good point Duke. This would be the most logical way (SOP) to do this. It applies to BJT's and JFETs as well.
Chris
12
4K
Kaz Kylheku
14
1K
phil-news-nospam@ipal.net
1
772
nospam.clare.nce@sny.der.on.ca
