So I am trying to use a 32 Button PCB Board to make a dashboard for ETS2. I have managed to make a couple of switches work (Key switch and some ON/OFF/ON switches uses to lift and lower the axles on the truck and trailer) however now I am onto the gear knob. Now I have managed to get this to work before however I had to extend the cables using some very thin wire to make them fit into the terminals on the PCB but these were snapping at the ends under the weight so I cut off the extensions and re-soldered them on using thicker wire. Now here's were I am having the problems the button on the tip of the gear knob and on the side which is used for high and low range are working as they should when tested on the multi-meter and when plugged into the PCB Board but the button on the front of the knob to split the gears works fine on the multi-meter but when I plug it into the PCB it is always active. However this doesn't change no matter which terminal the wires are plugged into. And as I've said I know it's not the switch because I have tested it with a multi-meter and it works fine and it did before I replaced the wire. However this is the same wire that I used for the other switches as well. So if anyone can help me diagnose the problem that would be much appreciated.
Thanks, Alex
Thanks, Alex
