H
Hank
Ok, I just realized I might need 4 total DAC outputs and my uC only has two 16
bit pwm outputs and one 8 bit.
Well...what about buying a single channel 10 to 12 bit medium speed DAC (about
$3 or so) and a $0.25 eight channel analog multiplexer/demultiplexer like a
74HC4051 and four 0.1uF caps to hold the voltage values. If I choose a DAC with
a 10uSec settling time (common), I can "refresh" each cap at about a 25khz rate
and buffer each with an op-amp. I would then have a 4 channel DAC for about the
cost of a single channel device.
I think the pwm scheme would be too slow to multiplex out in this fashion, so I
would have to splurge and buy the one channel DAC. Still, it is a design
savings of $9 or so, which is more than the uC costs.
opinions?
opinions?
