G
Guest
The system only works if the radio is installed properly. The vessel has to
have a registered MMSI number which is programmed into the radio. The radio
has to have a NEMA input for it to have position info.
Press the distress button without those and you get allot of noise and no
info.
Check the web for "GMDSS". The A3 terminal installation which I recently
completed cost over $36K. This was for an ocean going vessel.
The US is way far behind the power curve when it comes to safety monitoring.
As for your question, I know the Furuno radios will listen on both 16 and
70. They should, they cost us enough.
Following from the ICOM web site:
Built-in DSC capability that meets U.S.C.G. SC-101
The DSC watch function monitors Ch 70, while receiving another channel. It
allows you to send a formatted distress message in an emergency. The
position request function indicates a caller's position. Up to 30 DSC IDs
are memorized.
Andy K.
info.
are memorized.
Andy K.
