Welp here's how I did a Wine Temp Sensor with an XR200.
Zone Name - Wine Temp
Type - Aux1
Partition - 1
Area - Perimeter
DO Message - Alarm
DO Output - 0
DO Output Action - None
DS Message - Trouble
DS Output - None
DS Output Action - Steady
AO Message - Alarm
AO Output - 0
AO Output Action - Steady
AS Message - Trouble
AS Output - 0
AS Output Action - Steady
The output stuff is meaningless, their for controlling relays.
Supervisory may work for you too, but it won't clear until the room/refrig
goes back to normal temp...which may be annoying.
I've done these several different ways...mostly by experimenting
| > A homeowner with RemoteLink...I'm impressed.
| > DMP is really easy either way.
| > If you need help lemme know.
| > R.
| OK, after a couple of months delay, I am now ready to install both
| temperature and water sensors to my DMP200 alarm system.
| I intend to program it using RemoteLink but am a bit unsure exactly
| what values to choose since I don't have any examples of environmental
| sensors (I only have fire/smoke and burgular type zones).
| Can someone review my choices and let me know what I am doing right or
| wrong? (thanks)
| Note the fields are based upon the field names in the RemoteLink
| application.
| Zone Number: <new number>
| Zone Name: <name for zone>
| Type: Auxiliary2? Supervisory? (which is more appropriate?)
| (Choices are: blank, night, day, exit, fire, panic, emergency,
| supervisory, auxiliary1, fire verify, arming)
| Note: According to the manual definition, "Supervisory" seems
| like the best match, but someone earlier on the thread
| mentioned "Aux." If I do use "Aux", then I'm thinking that
| Aux2 may be better than Aux1 since you can set the "Zone
| Retard Delay Time" to avoid momentary transients setting it
| off.
| Partition: 1
| Area: -
| (Choices are: Bedrooms, Interior, Perimeter, -)
| If using "Supervisory", my programming GUESSES are as follows:
| DO Message: Grayed-out
| Fire Bell Output: 0
| DO Output Action: Grayed-out
| DS Output: Grayed-out
| AO Message: Trouble
| AO Output Action: Steady
| AS Message: Alarm
| AS Output: 0
| AS Output Action: Steady
| If using "Auxiliary", my programming GUESSES are as follows:
| DO Message: None
| DO Output: 0
| DO Output Action: None
| DO Message: None
| DS Output: 0
| AO Message: Trouble
| AS Message: Alarm
| AS Output: 0
| Prewarn Keypads: Grayed-out
| Entry Delay Number: Grayed-out
| Swinger Bypass: no-check
| Retard: no-check
| Fast Response: no-check
| Cross Zone: no-check
| Priority ZOne: no-check
| Wireless: no-check
| Any comments and help on the above are more than welcome...
