Randy MacKenna
I have a motor with a diffential optical encoder (A and B outputs),
which is configured as a 1000 count-per-revolution device. I really
want this thing to be a 250 CPR device...so rather than replace the
encoder, I figure there must be an easy way to divide the pulses coming
out of the encoder.
It's been years since I've played around with this stuff...so is it
as simple as piping the A and B outputs of the encoder into two
separate 4024 ICs, and then picking off Q2 of each, as the new output?
Also, the encoder I have says it is a "line driver" output. Does
that mean it is 5V, but can sink more current than typical TTL? If so,
I think I'm okay if I just put my 4024s within a few inches of the
motor control, correct?
Last stupid question: If the output signal from one channel of the
encoder looks like this:
____|-|_________|-|__|-|__|-|________________|-|____|-|___|-|____|-|_____
Does the output of Q2 on the 4024 look like this?:
__________________________|-|____________________________________|-|_____
In other words, is Q2 only transmitting every 4th pulse? That's
exactly what I am looking for, since I want to be able to tell the
motor control software that the shaft is in the spot that it would be
in, if the encoder were 250 CPR instead of 1000 CPR.
Thanks for your patience & help.
-Randy
out of the encoder.
-Randy
