Stereo Plug/Jack Standardization
Jim Thompson
Is there any standardization of the connections to stereo plugs/jacks?
Tip: Left (or Right) ??
Ring: (Right (or Left) ??
Inquiring minds want to know ;-)
...Jim Thompson
Y
YD
...Jim Thompson
Yeppers, tip: left, ring: right. You can find this on any number of
audio sites. Also, when cooking up a batch of patch cables I always use
red: left, white: right. I can't swear to this being a standard (I
recall having seen it) as I can't find any references right now but it
works for me.
- YD.
John O'Flaherty
works for me.
I thought it was red for right and white for left. Looking at the back
of my Sony mult-disk player confirms it -- the jacks themselves are
color-coded that way. Anyway, if they're backwards when you're
listening, all you have to do is swivel your head around 180 degrees.
Richard Crowley
Tip = left
Ring = right
Convention from 1/4 inch days perpetuated into the 1/8
inch (3.5mm) portable device generation with the Sony
Walkman, et.al.
Impedances and sensitivity are a whole 'nuther couple
of matters, however. Recent discussion over on r.a.p
Y
YD
The patch cables won't affect the "sided-ness" of the signals, it's
still tip-tip and ring-ring. In fact, you can use any colors you like
or have handy as long as you're consistent about it.
- YD.
buck rojerz
works for me.
- YD.
Check out any VCR. Red = right --- Left = white
I have always used (R)ed = (r)ight as found to be true in any audio
device(using colored connecters) I have come across. R = r is the
convention that holds true 99.9% of time. IMHO
buck
GregS
or Ring, starts with R.
greg
buck
Just when I thought thinking the world was synchronized I found out
the tape adapter I am using to feed MP3s to the car stereo is backward
from the sub woofer and they are out of phase. It sounds nasty.
Eeyore
The question was about a stereo jack.
Graham
Y
YD
buck
Yes, but those are RCA jacks, not the 3 mm stereo plugs this started
out about. Anyway, for the patch cables it's mainly a matter of which
goes where, the colors of what goes in between don't really matter.
Easy enough to change over next time I make a couple. Sometimes I've
had to make do with blue and yellow.
- YD.
Richard Crowley
(GregS) wrote :
Very good! I hadn't thought of that one. I knew the tip was left,
but
your offering is clever.
An old telephone installer once told me their mantra
was "red-right-ring"
