Does anyone know of stereo earphones with a connector with four
conductors? (ie., they don't share the ground node). I would like to
drive them in a bridge-tied load (BTL) configuration, to save the
coupling capacitors.
Thank you
And then you end up with not being able to use just any headphones simply
because you don't want the capacitor. Headphones are the thing that's
likely to break first, and you've ended up with a situation where the user
will then end up not being able to use the gizmo since they have to order
the headphones from some single source in New Jersey.
I have a headphone jack on the car radio that I use as a bedside radio. I
put the capacitor on it so I could use a single output of the car radio to
feed the headphones. I sure didn't need the extra power of balanced
output, and the capacitor was hardly "large". You should have been around
forty years ago, then a 10,000uf capacitor at 17v was the size of a coke
can. Now, it's not any extra size.
Since this sort of thing is dealt with all the time in commercial
equipment, you've made the issue more complicated than necessary. They
live with the usual headphones, and thus they must live with the "nasty"
output capacitor. On the other hand, my Sansa Fuze is small enough that
there must be miniscule capacitors at the needed capacitance, since all of
the unit complete with batteries and LCD screen is jammed in that tiny
package.
Michael
