Hi All
I'm in the early stages of designing a motorised focusing device for my telescope. I will be using a stepper motor a pic microcontroller and a SN754410 motor driver.
Here are the specs for the stepper I have available:
Model 35BY412L
Rated Voltage(v) 24
Resistance(ohm) 5
Holding Torque(gf.cm) 450
Detent Torque(gf.cm) 90
Rotor Inertia(g.cm2) 7.8
Number of Phase 4
Step Angel 2-2 Phase Excitation 7.5
Step Angel Precision ±0.5
Height(mm) 22.2
My question is how do I know how much current the stepper will draw? I can see from the motor driver ic datasheet that it's rated to one amp. Is this chip able to handle this motor. The stepper is rated at 24v and has a resistance of 5 ohms. If v=ir does that mean the motor is capable of drawing (24/5) amps? Seems like a lot for this sized motor but I was never good at theory. If it is the case, I'll probably need a less current hungry stepper as the final design will need to be battery operated.
Model 35BY412L
Rated Voltage(v) 24
Resistance(ohm) 5
Number of Phase 4
Height(mm) 22.2
