U
Ulrich G. Kliegis
Hi all,
I have a Navico (the old original) Corus nav electronics net on my 33
ft sailing vessel. The boat has a steel hull.
Already in the past season, the log sometimes was a bit slow to start.
I thought it was fouled, but then found out it wasn't. This year, it
refused to work so far, i.e., it shows 0 knots no matter how fast we
go.
So, I pulled the sensor out (Navico makes that possible even in the
water by a well working auto-closing valve and a temporary replacement
for the sensor housing).
That allowed me to test the sensor (the rotating wheel variety) in the
dry while being afloat. Surprisingly, the wheel rotated freely, and
when I pushed it or blew at it to make it rotate, the log display
showed reasonable values.
Fine, I thought, maybe just something that got stuck and fell off now.
So, I re-installed the sensor and was curious for the next trip. You
guess it: 0 knots.
The hull around the sensor is level and clean, there is nothing that
could disturb the sensor.
Now, my idea is that the steel around the sensor could be the culprit.
It may have become permanently heavily magnetised (maybe by a
replacement for a hole quite close to the sensor that we welded in
place (after removing the sensor, of course). This increased
continuous magnetic field might 'blind' the sensor coil (flush-insert
while re-reading this: Or is it a hall sensor? That would make even
more sense!) in the log. Or even simpler, the little magnet in the
shovle wheel might have become demagnetized for any reason.
Has anyboy of you experienced such a demagnetized sensor wheel, or a
magnetic saturation by the steel hull? It puzzles me that the thing
works if I pull it into the boat and doesn't if I put it back.
The cables are ok, I've triple-checked them.
Any other suggestions?
Thanks in advance for any helpful hint!
Cheers,
U.
go.
guess it: 0 knots.
Cheers,
U.
