Hello guys,
I have an issue with a medical compressor not being able to restart the motor once the first pressure level is reached and motor stopped. After pressure level drops - engine used to re-start automatically but after a few years the power need to cycle on the compressor to make the motor work again (and then it repeats - motor never restarts automatically as it used to do before).
Manufacture suggested replacing a motor capacitor and sent a replacement.
The rating on currently installed capacitor is 22.5 uF and the replacement I got is rated 15 MFD (same voltage range)
I am hesitant to install it because I feel the difference is too big (over the 5% tolerance).
I sent my concern to manufacturer but I am being assured that the capacitor they sent me would be OK.
I'd like a second opinion on how dangerous it may be to replace a Start/Run motor capacitor with a smaller value because replacing the whole motor on this equipment will be quite expensive if it burns.
Thank you!
Thank you!
