Spehro Pefhany
Anyone make a standard plastic USB dongle housing? Preferably on the
generous size.
TIA
generous size.
TIA
generous size.
TIA
Spehro Pefhany said:That looks pretty good... 19mm x 45mm PCB.
Thanks! The distie search engines don't do very well on enclosures.
Farnell sell that one, and one other...
Would you sell a product based on a case from a 3D printer ??3D printer ;-)?
Which 3D printer are you referring to ?Absolutely.
It depends on the application.
Already a lot of stuff is sold made with 3D printer,
for example you can order dolls made to your own specs.
Gears and parts of the 3D printer are made with a 3D printer too.
There is absolutely no reason why you cannot make something as simple and small as a USB stick case
with a 3D printer, and it likely will last many years, more then it takes for that sort of stick
to become obsolete.
3D printer ;-)?
They are nice toys, but not ready for including into a product.
hamilton
The ones available in Colorado, produces a product that is brittle and
looks sloppy.
The cost for one molded part is huge.
The cost of 100s or 1000s of 3D printed parts is also huge.
Where will the cross over be ??
Thank you for that endorsement.You are obviously not working in the industry.
They work to quite tight tolerances and can obtain good surface quality
finish, if needed.
We printed a cad model of a test jig for a device and mounted the
connectors on it and wired it up. works great, and nobody had to be paid
a tooling cost, and now we have 5 of them, and they are even light enough
to mount onto the device in build, and get sent to test already in the
fixture.
3D is great!
You are an idiot.
