Hello,
My 10 yr old tv has developed a problem of shutting itself off after working perfectly fine for few minutes. Both picture and audio shuts off with power LED green and Sony logo lit. If I turn it off for little while, it works fine for little bit before repeating same symptoms. It seems, the backlight does turn off when this happens along with no audio.
Initially I thought, it was a overheat problem but problem persists after cleaning it thoroughly from inside. Weird thing is, if I use it with the back open, it works perfectly for hours but as soon as I put the back cover back on and hang it, it starts acting up. I've also verified that cooling fans are operations.
Now I am thinking it could be some sort of feedback protection circuit that's turning it off. GF1 power board looks good with no apparent capacitor damage/leakage. Obviously, everything else works for few mins when I first turn it on before going dark.
I don't want to start throwing parts at it. I would appreciate your input to get a direction on this.
Thanks -
Thanks -
