The fuse is there to blow if something draws excessive current.
Shorting out the fuse might be fine if the fuse died due to some transient overload, but leaves the board and the power supply (and potentially your home) unprotected.
If there is a board fault which blew the fuse, the excessive current has not been allowed to flow. Maybe something else burnt out, reducing the current (and hiding the location of the fault),
The best thing to do now is to remove the solder bridge and replace the fuse. See if it blows. If it doesn't, at least we know that the power supply is safe from (possibly further) damage.
You were getting a replacement board anyway weren't you?
Probably worth waiting for it and seeing if it fixes the fault. At least that will confirm that it is this board that is faulty.
It also allows you to compare the two boards to play a game of "spot the difference" (a very useful fault-finding technique)
Ok wonderful. Would a place like Fry's electronics have a smd fuse like this one requires? I did buy a new board but it was the main board, which did not fix the issue obviously, but was not a total loss since the main board had some light water damage.
Do you know if the UB1 board is responsible for the power to the t-con and could be the problem? Or is my best bet to just find a new t-con
Thank you steve
