hi
i have few ac to dc smps adapters the light weight ones..
the spec on it says output 9volts 1 amps...
it has a round pin ... the outer connecter is negative adn the inner is positive..
when i measured the dc voltages it was 9.2 volts oc.. and when i measured its ac voltages it was like 25 volts.. y is this ? i am using a cheap DT-830B multimeter... also the 25 or so volts were shown when i connect the positve lead of mm to the inner connector and black lead to outer.. if i reverse the probes then it shows 0 volts... ? my wifi router is behaving frantakly dont know whats the issue . however after restarting it it works..
also this is aftermarket adapter for my router... the router needs 9volts 1 amp dc .. thats whats written on adapter adn in the manual ( TPlink wr740n) ..but the original adapter that came with this router was a big fat havy transfomer based adapter .. and the fck was that that was 12 volts output ... labeled and measured ... i dont know how it worked for a year in my device before stoping to work... and when it stoped working i opened it ... and to my surprise it was having just a transformer .. there were no capacitors...no diodes... no resistor... it was in other words just an AC adapter... how could it have worked and also for such a long time.. so when it stopped i bought the above mentioned smps adapter..
also another question regarding these adapter thingies...
i have a ZTE 831II adsl modem .. the input of the modem is labellled 9volts ac ( the ac symbol ~ is there instead of dc symbol = with the lower line dashed ) ...and the adapter is also ac .. its oc volts are 10.3 volts... can i replace it with some dc adapter.. ? or i must use ac adapter ? as i suspect that its adapter is causing problem ..
these two devices are connected together and i have some time to restart one sometime the other for the setup to work..
