Hi all,
Recently while using my soldering iron, I heard a sudden popping sound and the wire started smoking. When I opened the outer case, I found a small black burnt spot on the wire.
What could be the possible reason for this? Will it be fine if I cut the wire till the black spot and strip and connect the remaining part of the undamaged wire to the heating element? Did not want to take risk as this directly connects to main supply.
Thanks in advance.
Thanks in advance.
