solar cells to lead acid battery charger with pic single chip computer
walle62
Dear Friends
I must design for my company a solar cells (17 V nominal) to lead acid
gel battery (12V nominal, 14.6V charge final voltage) charger.
I want to use a pic single chip computer with A/D and D/A-converters
for regualting between solar cells and battery/load line with two
cool-mosfets (these are the same as a logic level mosfets). the unit
should also prevent against solar back current in the night,
overcharge, undercharge and load over current.
I also must implement a battery charge measurement (in Ah), i want to
do this with the pic (measuring the battery charge/discharge current
and integrating this current up/down respectively).
The surge load current is 20A or 40A, nominal load current is about 5A
or 10A.
Do you have ideas, critics, questions or suggestions? I'm glad about
every answer from you. I also would like to help somebody with similar
questions. For a very helpful idea or a good design we would pay, if
you want. Thank you very much!
Walter Nussbaum, dipl. Electronics Engineer ETH, Megasol Inc.,
Höhenring 17, 8052 Zürich
mail: wnussbaum@gmx.ch
phone: +41 43 268 90 32 mobile: +41 79 297 62 78
martin griffith
Dear Friends
or 10A.
check the archives here, Larwe posted a simalar question recently
Newsgroups: sci.electronics.design
Subject: Request comments on simple solar charger
Date: 23 Jul 2005 16:31:12 -0700
Organization: http://groups.google.com
Lines: 24
Message-ID: <1122161472.683715.123110@o13g2000cwo.googlegroups.com>
martin
walle62
dear martin
thank you very much for your answer.
i read in the archive, especially this article from jul 23 2005. it was
very interesting and i learned something new again.
yours sincerely
walter nussbaum
mail: w.nussbaum@gmx.ch
I
Iwo Mergler
walle62 said:
Dear Friends
or 10A.
You may want to consider optimising for maximum power
from the solar cells. Basically, you build a switch-mode
battery charger which regulates it's power troughput
to maximise I*V on the solar cell side.
That would allow you to extract maximum power under
a wide range of conditions with less dependency of
full sunlight.
Kind regards,
Iwo
walle62
Hi Iwo
Thank you for your answer. It's a good idea to use MPT, although it
makes the SW a bit complex. But it's worth while to think about it.
Kind regards
Walti
walle62
Dear Chris
You're absolutely right, but my chief want to design a own one..
Thank you very much for your suggestions.
walti
Chris Jones
walle62 said:
Dear Friends
[snip]
Depending on cost and quantity, you might be able to buy this more cheaply
than designing it. Have you read homepower magazine?
http://www.homepower.com/
There are lots of advertisements in there for charge controllers etc.
Chris
